subterratigress subterratigress is offline
Default Mini 10 w/Ubuntu screen brightness auto-adjust - 01-22-2010, 01:36 PM
I love my purple Dell Mini 10, running Ubuntu. Its awesome for note-taking in class and recording stuff, love it. But I have one problem: the screen brightness auto-adjust is a bit stubborn. I like the screen brightness to stay at the lowest setting while in class. I can lower it myself using the F4 key no problem. But if I don't touch the keyboard for about 30 seconds, and then start typing again, the screen brightness jumps up to about half of full. How can I get it to stop doing this? It interrupts my note taking to keep reducing the brightness. I am wondering if there is a Linux command or something that would fix this? My husband is a computer engineer, so if someone has a technical fix, don't be afraid to post it. If I don't get it, then he will!
Thanks in advance!
PS: I did look through the forums but I couldn't find any threads pertaining to my issue, but I apologize if I'm being redundant and I just missed it somewhere.
Default 01-22-2010, 10:31 PM
Look under "System menu > Preferences > Power Management". Try unchecking "Dim display when idle".
Default 01-25-2010, 09:42 PM
that fixed it, thanks!
« My Battery core is loose i think! HURRY IT WILL RUN OUT OF BATTERY!! | What is the Fn for? How to adjust sound? Is there a calculator keypad? »
