jgr789 jgr789 is offline
Default How do I know if my mini has bluetooth? - 01-17-2010, 06:51 PM
Is that information listed somewhere?
Default 01-17-2010, 06:56 PM
You can check your invoice. You can enter your service tag on dell.com to see the factory config. You can check Device Manager in Windows, or use "sudo lshw" (list hardware) in Linux.
Default 01-17-2010, 07:02 PM
Wow! that was fast! Thanks very much!
w7ox w7ox is offline
w7ox's Avatar
Default 01-17-2010, 07:07 PM
So does it or doesn't it? My 10v did not, but I was able to add it with a module from eBay for about $25.
Phil
Default 01-17-2010, 07:13 PM
Not that I could see on the device manager list. What would it be called for mini 9? Did it have to be installed internally? Or is it something that could be plugged in on the outside?
w7ox's Avatar
Default 01-17-2010, 07:16 PM
Can be internal or you can buy a $25 or so BT usb dongle (small stick). Make sure it will work with your OS, though.
Phil
Smile 01-17-2010, 07:20 PM
Thanks again! I'll look for a dongle that works w/Win XP.
Default 01-17-2010, 08:34 PM
dont know where u live but around me Best Buy has a USB Bluetooth adapter for $20...
Default 01-18-2010, 11:19 AM
Good to know. Thanks!
« Totally the FNG here but to get some input | Which to Buy - Mini 10 or 10v »
