Nickob Nickob is offline
Default Disc capacity issues - 01-06-2010, 02:54 PM
I was delighted to receive my mini 10 for Christmas (8bg hd, Ubuntu) and decided to upgrade the system to Windows XP pro. Initially I tried to do this via a memory stick but that was unsuccessful. The system seemed to be installing but came to a grinding halt after a few minutes. I bought a removeable CD drive and installed successfully throught that.
However, when the system boots up, I am given two options to install windows, both looking identical. The first option is the default one which boots the machine, but if I select the second option, I get the same error message as I did when I unsuccessfully installed xp. It seems as though it's on there twice!
I also notice that with only a couple of programmes loaded (around 1/2 GB total), a massive amount of disc space has been used - a little under 5 GB!
I have read posts from other members about the Page File setting, and to check whether hibernation is on, but I doubt whether this will explain all the missing space.
Can anyone help? And does anyone know how I can delete the frist screen, giving me the two identical power-up options?
Thanks!
Default 01-06-2010, 03:09 PM
Right click My Computer, go to Properties and click the Advanced tab. Click the Settings button under Startup and Recovery. Under Default Operating System you should have a drop down box with two options, the two XP instances presented to you at boot.
Now, if you don't select one and let it time out, does it go to the bootable install or the failed?
If so, then change it to the other option in the drop down, then reboot to verify. After it goes to the real install by default go back to these settings and uncheck the "Time to display list of operating systems" checkbox.
C:\M11xR2\320GBHD\4GBRAM\W7HP
D:\duo\320GBHD\2GBRAM\W8DP
Default Many thanks - 01-06-2010, 03:52 PM
That's really helpful, thank you. If I let the machine time out, it boots successfully, so I assume I just uncheck the box as you suggest.
Nick O'B
Default 01-06-2010, 04:05 PM
Bingo!
After you uncheck that box, click Apply and Okay, then click the Settings button under Performance, click the Advanced tab, and at the bottom you'll see Virtual Memory and how much drive space is allocated.
I'm not sure the recomendations for this with SSD's off the top of my head, but think it can be set to No Paging File for your C: drive. If it starts acting funky or prompting Windows is low on virtual memory, then bump it back up to maybe 512mb and play with it.
Cool 01-06-2010, 04:07 PM
you can download EasyBCD and remove the option totally..its free..get it here:
Download EasyBCD 1.7.2 - NeoSmart Technologies
or if you are comfortable in the editor you can edit the boot.ini file and remove it there also and never see it again...just make sure you remove the right one....EasyBCD is menu driven and easier to use...your call...
Default Thanks again - 01-06-2010, 04:36 PM
I'm looking forward to having a go at these fixes. Thank you very much, folks!
Nick
Default 01-06-2010, 06:41 PM
EasyBCD does not control the XP boot menu - it is for the Vista/Win7 style only.
Cool 01-06-2010, 08:31 PM
sorry, but it can be used for Windows XP, there are instructions on how to use it for XP, also I have it on my XP system and have used it to remove unwanted entries on my system..I have version 1.7.2, but in general it was designed to handle the Vista Boot loader files
Default 01-07-2010, 12:17 AM
Why do all that when you can just uncheck a single box? It's eating what in the boot.ini, maybe a few KB.......
« looking to buy a mini 10 | Mini 10 - Random crashes after installing ubuntu 9.04 »
