Igor Igor is offline
Default a few questions about my dell mini 10 - 11-17-2009, 06:48 PM
ive had my dell mini for a little while now an d have a few questions
wondered if someone could tell me the difference between all the dell mini 10's as theres a mini 10v and wondered how it was different
heres the spec on mine:
just wondered if i could improve the performance
it strugles to play a video i download from BBC iPlayer. i checked the performance whilst it played the video and here it is:
oh and this is a little wierd. when im on webcam, i open the settings and adjust them so i can be seen. as soon as i close the settings down it goes back to default (dark). i open the settings and it goes back to how i set it. so when im on webcam i have to have the settings box open which is really anoying! why doesnt it keep the settings when i close the settings box down?
cheers guys
fdalbor fdalbor is offline
fdalbor's Avatar
Default 11-17-2009, 08:23 PM
Your's is a Mini 10V. The 1011 refers to the 10v. The 1010 uses the Z atom processor, the 1011 uses the N atom. The 1010 uses GMA 500 graphics, and the 1011 uses the 900 series graphics processor.
The V is suppose to refer to the Value Mini (1011). It has a slightly lower power battery and you cannot get many of the options that a available for the 1010. You can get 2megs of ram in either; but you can upgrade the 1011 yourself (a bit difficult; but possible). You can get the high def screen in the 1010; but not the 1011.
What it really comes down to is you have a bigger selection of OS's to choose from with the 1011. However that is changing with the new Mandriva and Fedora and some others. IF you want to use Apple's OS then the 1011 is a better fit.
I have found XP and Win 7 work great on the 1010 as they make use of the extra features of the GMA 500 with the HDMI port; something the 1011 cannot do.
Take your pick; they both will do a good job for you. Just remember they are netbooks; not power desktops and you will find a multitude of uses for them. Enjoy your netbook. fdalbor
Compaq R4000 laptop AMD 64
Compaq SR2034NX AMD 64
« Question about hooking up my mini to a projector | What Bloatware Can I Uninstall? »
