MikeBabjak MikeBabjak is offline
Default Zagg Invisible Shield Question - 11-01-2009, 05:16 PM
Hi, I'm getting a Vostro A90 shipped to me.
Would the Zagg Sheild for the Mini 910 work for this? I believe it will, I just want a confirmation. Anyone use this product? Is it a decal? Case? Are there any snap on cases for the A90/Mini 9 out there?
Thanks!
Default 11-01-2009, 05:35 PM
It's a polyurethane film that protects very well against scratches and abrasion. It is pretty much invisible once applied and provides a bit of grip when holding the device. Yes, any product for the 910 will work with the A90.
Applying the film to a large surface takes a bit of care to avoid bubbles. Best to start at one edge and use the included tool to gradually lay down the film, squeezing out bubbles. Some small bubbles will remain for some days, but will usually go away on their own.
hotrodminis's Avatar
Default 11-01-2009, 07:22 PM
And mind the washing the hands and using the spray parts of the installation instructions. The zagg stuff can't be peeled up and repositioned like some skins.
Oh, and there are coupon codes for them all over the web - save at least 20% with a simple google search
Default 11-02-2009, 02:10 PM
Thanks, anybody know of a unit such as this: for the A90?
iPearl Inc - Light-weight, stylish mCover® Hard shell cover case for 10.1" Dell Mini 10 10v Netbook
Thanks again!
ChazB ChazB is offline
Send a message via MSN to ChazB Send a message via Skype™ to ChazB
Default 11-10-2009, 02:54 PM
Thanks again!
I'm not aware of one of those for an A90/Mini 9, but I have a new InvisibleShield I'm looking to get rid of. Still in the packaging, never used.
| Dell Mini 10 | Product Red Edition | 1.6GHz | 1.3MP | 160GB SATA HDD | Bluetooth | 802.11n | Windows 7 Ultimate |
| Dell Mini 10v | Obsidian Black | 1.6GHz | 2GB Kingston HyperX | 1.3MP | 160GB SATA HDD | Bluetooth | 802.11n | Windows 7 Ultimate |
Eagles may soar, but weasels don't get sucked into jet engines. - Unknown
Before Elvis, there was nothing. - John Lennon
bwong2 bwong2 is offline
Default 11-14-2009, 07:03 AM
there's a review of the mCover here if you haven't seen it yet.
« 10v Display gone VERY low res when bootup?? Any advice? | How does the mbr/grub get copied to an external usb drive for booting off of it? »
