Originally Posted by holmes4 Sometimes external CD/DVD drives need more power than is supplied by the USB port - this can result in flaky performance. If your drive has the option for separate power, use it. Otherwise use the USB port closest to the power jack. |
Thanks again! The external drive works fine, the only thing that it will open is the first CD of the set of 3. Called and talked to DELL Tech support,Their sending a new 8GB
SSD. I tried to get them to send a 16GB and I'd pay the difference but I'd rather talk to a ? shoe,board anything other than them to try to sway their policy.
Couldn't they just accept the difference in costs between the 8GB and the 16GB.Oh well I was planning on a larger
SSD anyway so I'll get a new 8.Anyone want a 8GB
SSD at a lower than new cost??
My CD/DVD is Samsung with duel USB wires for extra power when needed noAC adapter needed.
THANKS You seem like the only one here helpful for me!
