Ken56 Ken56 is offline
Default Built in mike? - 12-07-2008, 09:16 PM
Hi all, don't know if i'm being dumb but is there a built in microphone on the mini9? I can't get it to work on Skype if there is one, speakers are ok, can anyone help?? Ta, Ken
Quinten Quinten is offline
Default Re: Built in mike? - 12-07-2008, 09:53 PM
I believe that if you have the webcam, it will have the mic next to it.
Fallstar Fallstar is offline
Fallstar's Avatar
Default Re: Built in mike? - 12-07-2008, 10:33 PM
The built-in mic, on the Mini 9, is located on the bottom/front area, just under the trackpad.
The Setup Guide (PDF) page 16 & 17 show the location.
The little "hole" next to the webcam is some sort of activity light that goes with the cam.
Default Re: Built in mike? - 12-07-2008, 10:52 PM
Thanks, but how do I get it to work, which settings in Skype should I use? Sorry, new to Linux!
« DELL Mini 9 or 12 | Memory usuage unfound and not able to identified »
