Question Question about BIOS beeping sound - 10-10-2009, 05:10 PM
I just received my "previously ordered new" mini 10v from the Dell outlet store with my birthday money.
Before I begin to switch it over to Mac OS Snow Leopard by doing the
external case HD switch, I wanted to see how easy it was to hit F2 and F12 to
get into BIOS. I have ver A06. When I see press F2 or F12 I hit the keys sometimes it just boots to Win XP and when I restart and hit the keys again the computer makes a beeping sound before it goes into BIOS.
Is this normal? I am not a Windows person.
Thanks for your help.
Bear Hunter's Avatar
Default 10-10-2009, 05:27 PM
Hit f2 when you see the "dell" boot screen. It should go into bios setup everytime.
Dell Mini 10v • Mac OSX 10.6.2 • 1 GB RAM • 160GB HDD • BIOS A05 • Blue Tooth • 1510 WLAN 802.11g /n
NBI 8.2 -> NBI 8.3RC2 -> NBI 8.3RC3 -> NBI 8.3RC5 -> NBI 8.3 alpha
USB Legacy Disabled | USB Wake Enabled | BT Enabled |
www.suckerpunchent.com
Default 10-10-2009, 05:32 PM
Sometimes when I hit F2 it does NOT go into BIOS/
When it does go, is it supposed to make a loud beeping sound?
Default 10-10-2009, 05:42 PM
Yes, I recall it did make a beep when i did it. As far as hitting f2 and not going into bios, the only thing I can think of is your not hitting it at the right time. you realize you don't need to "hold" f2, just hit it at the Dell boot logo.
Talking 10-10-2009, 06:17 PM
Thanks, it worked.
I guess I was holding the key down to long or hitting it too late.
Well. . . here goes .... wish me luck .... I'm going to make my XP be
Mac OS snow leopard.
Default 10-10-2009, 06:26 PM
Thanks, it worked.
You don't need luck. Just make sure you understand the directions and follow them to the "T". When you get it installed go to settings/displays/color/ and choose "Acer1/Dell Mini". It will look a lot better than the default.
Default 10-11-2009, 03:14 AM
Followed all the steps except SOUND did not work.
Reran NBI .8.3RC and checked enable bluetooth and now I have
a mini MAC running Snow Leopard 6.1
Thanks for the hint on color display.
This board is the best.
Default 10-11-2009, 03:36 AM
If your sound isn't working do this:
Download: Snow Leopard "Verbhelper.kext":
http://www.mydellmini.com/forum/atta...1.0_sl.tgz.zip
1. Show hidden files (if you didn't select "show files" when you installed NBI)
2. Go to extras folder and replace the verbhelper.kext file (/Extra/mini*ext/) overwriting the old file
3. Run the updateextra application in /Extra. Reboot, and you'll be using the new kext
Default 10-11-2009, 06:32 AM
Thanks for the tip on sound.
It is working now.
Now I just need a way to cover the Dell circle with
an Apple sticker that would look good on the lid.
« General questions on the Mini 10/10V | new mini 10 z520 cpu 1gb ram 160gb hdd »
