tanjeraldyne tanjeraldyne is offline
Default mini10v XP preinstalled, dualboot DELL ubuntu, FAT32 data partition. help? - 10-04-2009, 01:56 PM
hi!
ordered a mini 10v (15% off) with XP. its on its way now.
want to dual boot it with DELL ubuntu.
also contemplating on creating a third (FAT32) data partition that can be read by both OS.
queries:
* where can i download the DELL ubuntu .iso?
* how do i go about doing this? steps please?
1. shrink XP partition; create another two partitions; install ubuntu on one of the partitions?
2. install ubuntu (will create its own partition?), create the 3rd data partition?
* can i use EASEUS partition tool to do the partitioning?
EASEUS Partition Master is a magic partition manager software for Windows 2000/XP/Vista/2003/2008 Server. Free for home users.
any help would be greatly appreciated..
thanks in advance!!!! c",)
jeraldyne
Default 10-04-2009, 02:28 PM
dell ubuntu iso - Google Search
The Ubuntu installer can shrink partitions. I think it's pretty straightforward.
I'd probably give Ubuntu a 6GB system partition. I prefer to run without a swap (virtual memory) partition, but you might want a swap partition equal or greater than your RAM, so that you can hibernate.
As for a FAT32 data partition, figure out how much space you need/want for the XP system partition, then shrink it appropriately. Then during the Ubuntu install (or afterwards), create a FAT32 partition, and set it to mount at "/home/user/tanjeraldyne/data" (that way it's conveniently mounted under your user dir). You can even mount it similarly under Windows, say at "C:\Documents and Settings\tanjeraldyne\My Documents\data".
You could also go without a FAT partition, and rely on Linux support for reading and writing NTFS. Then, you'd just want to make a folder in your user dir in Windows, then mount it similarly under Ubuntu.
Good luck.
More info on dual-booting: https://help.ubuntu.com/community/WindowsDualBoot
Default 10-06-2009, 12:35 PM
reflex:
thanksalot for the tips and the link. will go ahead and do it once the mini 10 gets here! c",)
« Mini means MINI, I want a 9! | Need help deciding from those who have them. »
