tezzer tezzer is offline
Default cant display any wireless networks - 09-25-2009, 09:46 AM
I have just purchased a used mini 1011 and tried to connect to my linksys wireless router but the mini wont show any available networks.
There is no problem with my router as i run another laptop off it with no problems,the mini works when connected through the ethernet cable device manager reports no problem with network card and i believe it has been used on a mobile dongle as t-mobile icon was on screen,can anyone help please.
hotrodminis's Avatar
Default 09-25-2009, 04:23 PM
First, make sure your wireless is turned on. The minis have a hardware switch that can turn it on and off. This one has gotten the best of us at times
Second, check your TCP/IP and make sure that you have it set to automatically get an address, rather than have it set at one particular address.
« Can a Mini 9 do Remote Access? | super n00b here... vostro coming, and just got hp 110..which one? »
