Mike_Smith Mike_Smith is offline
Default Base System Devices ??? - 09-02-2009, 10:56 AM
Hi,
I'm new here. I got my Dell Mini 9 yesterday. It's running Windows 7. I got 2 devices called "Base System Device" with unknown drivers...
I did some searching and have installed the "Dell Battery Meter/Wireless Select Switch",
"JMicron JMB385", "Dell Touchpad drivers" but still nothing has fixed it. They are still there. Please someone look at the attached pic and tell me what I'm missing
Thanks!
Retired Mini user
WolfKeeper's Avatar
Default 09-02-2009, 01:05 PM
Those base system devices are supposed to be the card reader. Windows 7 can use the SD portion of it, but needs the drivers to use the MMC and MS parts of it. Are you sure you installed the correct JMicron card drivers?
Getting an iPad
Default 09-02-2009, 01:22 PM
I tried the link for the Inspiron Mini 12 (1210) for Vista 32-bit.
Drivers & Downloads
ftp://ftp.us.dell.com/chipset/R200081.EXE
Is that the correct one?
Default 09-02-2009, 01:27 PM
Retired Mini user
WolfKeeper's Avatar
Try this one:
ftp://driver.jmicron.com.tw/jmb38x/X...00.32_WHQL.zip
It's from the manufacturer's website, and has been updated for Windows 7. I'm not positive that the Mini 12 and 9 share the same reader chipset.
Getting an iPad
Default 09-02-2009, 01:49 PM
WolfKeeper please could you download it and attached it as an attachment as I got not FTP access at work. Thanks alot
Retired Mini user
WolfKeeper's Avatar
Default 09-02-2009, 04:15 PM
Lets see if this works...
Getting an iPad
Default 09-03-2009, 06:50 AM
Thanks WolfKeeper. It's working now Both Devices are gone
BobCoxner BobCoxner is offline
Default 09-06-2009, 06:42 PM
I have a similar question. 10v, Windows 7 Pro RTM, clean install. Under Device Manager, "Other Devices" I only have an entry for "Unknown Device".
In the Control Panel, Devices & Printers, there's a yellow exclamation point for the 10v itself. When I right click on it and "Troubleshoot" it searches and after "checking for missing driver" I get "Unknown device doesn't have a driver".
Any idea what the device is?
Retired Mini user
WolfKeeper's Avatar
Default 09-06-2009, 08:42 PM
It the "smart battery" I believe.
Getting an iPad
« Where can I buy a Mini 9 drivers and restore disk? | Memory Trouble »
