BobCoxner BobCoxner is offline
Default 09-06-2009, 09:35 PM
Originally Posted by WolfKeeper View Post
It the "smart battery" I believe.
Thanks! It was indeed the Smart Battery. Problem solved.
SEinson SEinson is offline
Default 02-15-2012, 07:48 PM
Feb 15, 2012
Just upgraded to Win 7 Pro and RunCore 32G SSD. Install was perfect except for:
2 BASE SYSTEM DEVICE errors, and 1 Unknow Device error in Device Manager.
The machine appears to function perfectly even with those 3 error messages.
The TouchPad, Wire and Wireless LAN, Card Reader and Battery Meter all appear to be working correctly.
Your link removed the BASE SYSTEM DEVICE flags in Device Manager.
Now I have to work on getting rid of the Unknown Device.
If you have any advice on this problem I would appreciate your input.
Thanks for the great tip
ish05 ish05 is offline
ish05's Avatar
Default 03-04-2012, 01:00 PM
same problem...any help?
Dell Mini Inspiron 910 32GB RunCore SSD, 2GB RAM, Windows 7 Ultimate
Dell Inspiron 1720 2x 1TB HDD, 4GB RAM, Windows 7 Ultimate
https://www.facebook.com/pinto.ismael
http://gplus.to/ismaelpinto
  (#14) Old
Default 03-06-2012, 12:18 AM
Same solution.
  (#15) Old
ish05's Avatar
Default 03-06-2012, 04:27 AM
Thanks Holmes
« Where can I buy a Mini 9 drivers and restore disk? | Memory Trouble »
