k000 k000 is offline
Default 09-03-2009, 04:44 AM
Originally Posted by danmanx View Post
Wow! Crappy design!! I'm so glad that this forum is here to tell the truth and give factual information in places otherwise barren of specs.
Crazy. Ditto too on having a Mini 9 with it not sticking out. I'm so not getting a 10/12
You so should not I am truly sad
tiltiver tiltiver is offline
Default 09-06-2009, 11:44 AM
I never thought to use an SD card for storage (only has 16 gigs on the SSD :\), but now it seems like an incredibly good idea. And now useless.
The fact that it's a "feature" disappoints me. I see how it's trendy to have the SD card easily gripped and pulled out, but keeping the netbook as flush on the sides as possible is critical.
Default 09-06-2009, 12:33 PM
It's useful if you want to look at photos from a digital camera that uses an SD card. It's less useful as "semi-permanent" added storage, but all the models that have this mis-feature are available with reasonable-size hard disks.
  (#14) Old
Default 09-07-2009, 01:58 AM
You are right... I thought that too, would have loved to get this misfeature on my d430.. I guess I am one of the exceptions with Mini 10 to have chosen to get SSD (32 GB)
  (#15) Old
ludasco ludasco is offline
Default 09-07-2009, 02:09 AM
honestly, i think an external usb drive is a better solution depending on your application. Are you worried the card will break? you can get a usb card reader.
  (#16) Old
Default 09-07-2009, 04:05 AM
I was hoping to use the SDHC as expanded HD as I have only 32 GB SSD and not 160 GB HDD like most others...
  (#17) Old
faber78 faber78 is offline
faber78's Avatar
Default 09-07-2009, 05:46 AM
researched for anyone done an internal mod for added memory yet?
just trying to help, id be kinda p-d off myself....
  (#18) Old
Default 09-07-2009, 06:34 AM
There are some discussions about this. Apparently there is only so many times you can read from and write to a flash drive. Over time the information can become corrupted.
Also, it may not be all that fast.
I just dont know if the card will be the best solution depending on your application.
  (#19) Old
gtm gtm is offline
Default 09-07-2009, 03:53 PM
Google nano USB drives. http://technology-guide.co.uk/images...lash-drive.jpg
Great solution to this problem
Vostro 200MT - XPS M1530 - Mini 10v - e1505
« New to the whole "netbook" thing | Hey everyone. »
