mybearbow50 mybearbow50 is offline
Question Printer for Mini 10v? - 08-09-2009, 06:43 PM
Which printer should I purchase for my DellMini10. Just bought a 2.0 External Drive.....Can anyone help???????? Thank You
Default 08-09-2009, 06:50 PM
Netbooks should work with printers just as well (or badly) as a normal computer equipped with the same OS.
Default 08-09-2009, 07:31 PM
Where would you be likely to use the printer? A wireless one might make sense if you're going to print from the netbook at home.
MarkProvanP MarkProvanP is offline
Default 08-11-2009, 08:51 AM
HP printers work well with all OSes (Windows 32/64, Mac OS X, Linux, even the PlayStation 3 on some models). I got a HP Photosmart C6380 from Comet for £90, an All-in-one with WiFi and Ethernet.
« Can dualbooting be done after OSX install? | Questions About Dell Mini 10 »
