kap0w kap0w is offline
Default What does the battery app even do? - 11-24-2008, 05:41 AM
I just finished reinstalling XP Pro on my mini and was trying to decide if I should install the battery & wireless switch utility. I understand that if you have bluetooth (which I don't) it might be useful to be able to toggle the wireless on and off, but what the heck is the battery app supposed to do? Other than have a different display of the battery meter, is there anything *useful* it does? Hrm... I'm not gonna install it just for the pretty picture.
BrooksyX BrooksyX is offline
Default Re: What does the battery app even do? - 11-24-2008, 06:33 AM
its so you can turn wireless on/off as well. The wireless eats up a good amount of power so if your not near a wifi hot spot or arnt using the internet you can turn it off and get some more juice out of your battery.
Founder
Dunhamzzz's Avatar
Default Re: What does the battery app even do? - 11-26-2008, 10:52 PM
if it wasn't bundled with the WSS /I probably wouldn't bother with it.
AltrdGenetics AltrdGenetics is offline
Default Re: What does the battery app even do? - 12-03-2008, 03:06 AM
i went ahead and uninstalled mine. i wish that the battery would give me an ETA time so i have somewhat of an idea of how long i have till i need to seek an outlet. i Wouldn't bother with it if i were you either. it seemed like a worthless program to have as well as something else pointless that runs on startup
nollie nollie is offline
Send a message via MSN to nollie
Default Re: What does the battery app even do? - 12-04-2008, 03:12 PM
Are there any Battery Apps which do give an ETA for battery time remaining which is lightweight and runs in the tray?
Dell Mini 9 - 64GB Runcore - 2GB RAM - Windows 7 - 16GB SD - Jolicloud Beta
jelli794 jelli794 is offline
Default Re: What does the battery app even do? - 12-04-2008, 03:39 PM
I use BatteryBar v2.3 build 41. It goes in the corner to the left of the sys tray. It like it... give it a try and you prob will like it too.
« Quick Question | Ok Do I really need one. »
