slay3r slay3r is offline
Question Usb power consumption?? - 06-30-2009, 02:52 AM
Hello everyone,
I've a dell mini 9 and im planning to use all 3 usb slot with 8gb micro usb memory stick plus a 8gb sdhc card in the reader. I would have 32gb total.
I was wondering if i keep them permanently in there, will they use too much power? Will it be noticiable on the battery life?? Or do they use energy only when i will acess them??
Plus, im planning to buy a bigger SSD than my 8gb. Will the 32gb use more power?
Thanks for the help
Default 06-30-2009, 03:36 PM
There is very little current used when the flash memory is not being read or written. If your USB stick has an LED it draws more power than the memory does when idle. The SD card should make no difference.
There is some difference in power consumption between brands and models of SSDs, I don't think capacity has an effect.
Default 07-02-2009, 10:43 PM
cool thanks! i guess i have to remove the led on my usb stick if i keep them in there so it wont suck all power!
bunjin bunjin is offline
bunjin's Avatar
Default 07-02-2009, 11:34 PM
The power draw of your led isn't going to be worth removing it IMO.
Default 07-03-2009, 09:26 PM
ok ty
mehboob mehboob is offline
Default 07-04-2009, 06:27 PM
The current is very less when in-active. So you dont need to worry about it.
# Netbookfiles.com Your Netbook's Software and Driver Source!
« How to install a 32 GB SSD??? | Using Dell Mini 9/Vostro a90 with a Projector »
