Has anyone been able to get a Verizon UM150 USB Broadband Modem to work on their Dell Mini9 Mac? I am unable to get it to recognize the keystroke to bring up a Terminal window from within the VZAccess Manager. Verizon tells me that this is needed to update the "MIP"(?). They showed me how to do it on my standalone XP box.
They tell me that to do this, I need to press "Apple"+"Shift"+"T" and that a terminal window should open up showing me the available modems.
I tried manually opening up Terminal but it comes up with a standard prompt.
Do you think it could have problems with the keyboard mapping? When I try holding down the above mentioned keys, VZAccess Manager just buzzes back at me. I guess it doesn't like the Dell keyboard.
Any suggestions?
