fingersuk fingersuk is offline
Default Vodafone drivers on built in card - wont work with fresh ins - 10-25-2008, 07:08 AM
Rebuilt mini9 with custom xp pro nlite joined it to domain gave it local admin rights. Then installed software from dell cd vodafone software opens but doesnt find any drivers manage drivers doesnt detect it.
Help!! Got nice new mini9 but no mobile broadband now!
Thanks,
Chris
Nunim Nunim is offline
Default Re: Vodafone drivers on built in card - wont work with fresh ins - 10-25-2008, 07:30 AM
Does it show up in Device Manager?
Default Re: Vodafone drivers on built in card - wont work with fresh ins - 10-25-2008, 12:16 PM
It did when i installed R197332, however when its installing the drivers it says cant find section in the INF file and fails.
julesthorne julesthorne is offline
Send a message via MSN to julesthorne
Default Re: Vodafone drivers on built in card - wont work with fresh ins - 10-26-2008, 07:54 PM
Why change? Do y9ou need to join a domain for your work? I would have kept it with XP home. My home copy shows device driver as being the normal dell 5530 HSPA,I would expect these to work with Pro as they would with home.
Rgds
Jules
The future is bright - the future is tanagers G4 orange
Vodafone mini 9, 2 Gb RAM, 16 Gb SDHC Card, Win XP, Office 2K7
Default Re: Vodafone drivers on built in card - wont work with fresh ins - 10-28-2008, 07:33 AM
I believe the problem was with the nlite config in the end, I went for a full winxp cd and had to use xplite afterwards, not ideal but it worked.
strider_mt2k's Avatar
Default Re: Vodafone drivers on built in card - wont work with fresh ins - 10-28-2008, 12:11 PM
nlite strikes again.
acabtp acabtp is offline
acabtp's Avatar
Default Re: Vodafone drivers on built in card - wont work with fresh ins - 11-01-2008, 02:06 AM
overzealous use of nlite strikes again
« Battery Life with Vodafone 3G | Adding HSDPA Mini PCIe Card to UK model »
