terence10v's Avatar
Default Will this work ? - 12-19-2011, 02:32 PM
I have an old Inspiron 1520.
Behind the battery is a sim card slot, but no wwan in the compartment.
If i fitted the wwan card and attached the aerial wires that are there. Would this work on Orange UK network?
Mini 10v Black. Win XP, Bluetooth.
terence10v's Avatar
Default 12-20-2011, 11:43 AM
Any advice anyone ?
Default 12-20-2011, 07:27 PM
Is there a socket for a WWAN card? If there is, then assuming you buy a card compatible with Orange, it should work.
terence10v's Avatar
Default 12-21-2011, 09:42 AM
Thanks holmes4.
Yes there is a socket without wwan in, also the aerial wires are tucked into protective sleeve. Im guessing they are for wwan. They have same connectors as the WLAN ones.
Thanks again..
Wm.Mays's Avatar
Send a message via Yahoo to Wm.Mays
Default 01-24-2012, 07:25 PM
As you say the system has a pcie slot, sim card slot, and antennas, just installing the proper type WWAN card for Orange's network and installing necessary drivers should work fine.
If Orange uses GSM type system, make sure there is actually a sim card holder installed on the board. All systems have a slot, but not necessarily a card holder soldered to board. You can test by inserting sim card into slot. If it clicks in, then you're ok.
MINI 9: Jade Green, RunCore 64GB SSD, Hyper-X 2GB RAM, Dell 5530 WWAN Card, Dell 1505 WiFi Card, Bluetooth 2.1, 1.3MP Webcam, Leopard 10.5.8 NBI 8.0.3 Final, BIOS A05
« Looking for internal WWAN card recommendation/source | New firmware to 7.2Mb »
