  (#31) Old
Joker051386 Joker051386 is offline
Default Re: VERIZON WORKS on MINI9!! - How do you open the USB720? - 04-20-2009, 04:19 AM
Originally Posted by jdonalds
I just bought a USB720, activated it on a windows box, but now I can not figure out how to open it..
I see one torx screw...but even with that off I can't get it open...
Those screws only hold theplastic antenna, I used a flat head screw driver which I use to crack it open just be careful
  (#32) Old
Ellerbestyle Ellerbestyle is offline
Default Re: VERIZON WORKS on MINI9!! - 05-10-2009, 03:27 AM
So I am guessing I could do this with a Sprint USB card and change it out. Hmmm need to figure out what USB card to get and try it.
  (#33) Old
AaronASB AaronASB is offline
Default 10-12-2010, 05:08 PM
Bump with easy snap on antenna Antenna for Wireless 3G/HSDPA/HSUPA/GPS WWAN Mini Card - eBay (item 170490756038 end time Oct-21-10 19:34:24 PDT)
There are many chinese sellers of these antennas. Search for "antenna wwan" on ebay. No need to solder for an hour and tinker, these work well specifically with the usb720, buy two and place them apart.
« Does anyone have the T-mobile US 3G WWAN Card? | Found 3g modem on my new 1012 but cannot enable it »
