gregmape gregmape is offline
Default Wireless Manager will not turn on - 06-13-2010, 10:07 AM
I have a mini 910 running XP with a 3 Data Sim card fitted. The Wireless manager sometimes gives an error & will not turn on,
The only way out I have found is to do an F9 bios command to load defaults. When I then launch the Wireless manager it works & I can connect to the 3 Network in the UK.I have loaded A06 BIOS,
Any Ideas how to get the wireless manager to work?
« HSPA/EDGE low reception, in a full signal area. | Problem GPS with d5530 »
