MIVELD MIVELD is offline
Default Help on Sharing HSDPA Connection - 08-28-2009, 03:56 PM
Wanting to share my Vodafone (UK) HSDPA connection with another laptop
Have managed to share the connection with the LAN port so the other laptop can connect wired
Is it possible to use the WIFI on my Dell mini 9 to pump out a connection to another laptop on WIFI
Any suggestion appreciated
Many Thanks
DJ_Elo DJ_Elo is offline
Default 08-28-2009, 11:07 PM
well u shud be able to create an ad-hoc wireless connection between the two and then just bridge the hsdpa and wifi connection so the other laptop can access the net.
check in ure network center, create new network>wireless>ad-hoc etc..once done bridge them and should be sweet
yaqbpl yaqbpl is offline
Default 09-01-2009, 06:44 PM
« New AT&T Communication Manager for Windows 7 | unlimted internet on sprint »
