ninvin21 ninvin21 is offline
Default Mobile Capped at 5GB Per Month? How much data is that?Also How Fast is It. - 07-31-2009, 03:17 AM
I have a 10v and I'm thinking about geting a USB mobile Modem.
Most movies are 4.7 to 8 GB.
Just Say I were downloading a movie (That I own)
So I could only download 1 Movie Per month?
I don't understand.(there's no way that's right)
Also How is the speed compared to Dial up,DSL,and Cable?
Thank you so much I can't find good info anywhere?
I Don't know anyone with A Mobile Modem.
TchnclFl TchnclFl is offline
TchnclFl's Avatar
Send a message via AIM to TchnclFl
Default 07-31-2009, 03:59 AM
If your plan is only 5GB per month, then yes, you could only download 5GB a month (including web pages). Those types of plans aren't made for constant use; they're made for use on the road, etc. If you want something to be downloading a lot on, then you should get Cable (in my opinion).
Default 07-31-2009, 07:35 AM
Thanks for setting me straight Yeah I have cable,I was thinking of replacing it with mobile broadband for the obvious reasons But I guess Not.
(Wow that's expensive It's the same price I pay for unlimited cable)
When I first saw you Could access the internet Via cell phone I new the day was coming where you could have internet anywhere on a PC, I Just hope in time the take the cap off and speed it up.
Thank You Very Much
« Can I put a 3G card in a 10v | UK 3G provider for Mini running OSX? »
